Skytex SP728 Case Replacement
  1. Skytex SP728 Case Replacement, Case: step 1, image 1 of 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Case Replacement: step 2, image 1 of 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Case Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Case Replacement: step 4, image 1 of 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
To reassemble your device with a new case, follow these instructions in reverse order.
Michelle Strickland
304 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 213
