Skytex Skypad Alpha 2 Back Cover Replacement
  1. Skytex Skypad Alpha 2 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Back Cover Replacement: step 2, image 1 of 2 Skytex Skypad Alpha 2 Back Cover Replacement: step 2, image 2 of 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Back Cover Replacement: step 3, image 1 of 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Back Cover Replacement: step 4, image 1 of 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
2 other people completed this guide.
Elizabeth Wittliff
176 Reputation
1 Guide authored
Baylor, Team 6-5, Williams Fall 2015 Member of Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 312
