Slime Portable Air Compressor Motor Replacement
  1. Slime Portable Air Compressor Motor Replacement, Getting Started: step 1, image 1 of 1
    • Unscrew the back cover.
  2. Slime Portable Air Compressor Motor Replacement, Remove the Cover: step 2, image 1 of 1
    • Remove the back cover.
  3. Slime Portable Air Compressor Motor Replacement, Remove the Light: step 3, image 1 of 2 Slime Portable Air Compressor Motor Replacement, Remove the Light: step 3, image 2 of 2
    • Remove the light fixture from the slot in the front.
    • Be careful when removing the circuit board from the base so the wires don't break.
  4. Slime Portable Air Compressor Motor Replacement, Remove the Motor Cover: step 4, image 1 of 1
    • Pull the black end cover on the motor off and set aside.
  5. Slime Portable Air Compressor Motor Replacement, Remove the Gauge Cover: step 5, image 1 of 1
    • Unscrew the gauge back cover and remove.
    • Set the screws and the cover aside.
  6. Slime Portable Air Compressor Motor Replacement, Remove Gauge: step 6, image 1 of 2 Slime Portable Air Compressor Motor Replacement, Remove Gauge: step 6, image 2 of 2
    • Remove the pressure gauge.
  7. Slime Portable Air Compressor Motor Replacement, Remove the Hose: step 7, image 1 of 2 Slime Portable Air Compressor Motor Replacement, Remove the Hose: step 7, image 2 of 2
    • Remove the hose by unscrewing it from the motor.
    • Set the pressure gauge and hose aside,
    • Take care when removing the hose to hold on to the spring inside.
  8. Slime Portable Air Compressor Motor Replacement, Remove the Motor: step 8, image 1 of 1
    • Pry the motor up from the base.
  9. Slime Portable Air Compressor Motor Replacement, Unplug the Motor: step 9, image 1 of 1
    • Unplug the black cord connected to the top of the motor.
    • Remove the motor.
  10. Slime Portable Air Compressor Motor Replacement, Replace: step 10, image 1 of 1
    • Replace the motor.
  11. Slime Portable Air Compressor Motor Replacement, Reassemble: step 11, image 1 of 1
    • Reassemble the air compressor and continue use.
Taylor Bratsch
346 Reputation
2 Guides authored
4 Guide Comments
I burnt my slime rechargeable compressor, model 40028. Do you know if the dc motor is the same for all models. Or, will I have to look at the motor once I get it out.
David R Robinson - Reply
I have since opened my slime air compressor, removed the motor and there are no markings on it for a model number or identifying features.
David, did you ever figure out the motor? Also, where would one buy a replacement motor?
DrmrDee10 - Reply
article is good but i read an article about craftsman air compressor so, i want to tell you that its a great info about this. You can also read here : https://inflatorsguide.com/craftsman-air...
Inflators Guide - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 2,752
