Smart Parts Ion Battery Replacement
  1. Smart Parts Ion Battery Replacement, Hopper and the Air Tank: step 1, image 1 of 3 Smart Parts Ion Battery Replacement, Hopper and the Air Tank: step 1, image 2 of 3 Smart Parts Ion Battery Replacement, Hopper and the Air Tank: step 1, image 3 of 3
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Smart Parts Ion Battery Replacement: step 2, image 1 of 2 Smart Parts Ion Battery Replacement: step 2, image 2 of 2
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
  3. Smart Parts Ion Battery Replacement, Smart Parts Ion De-Gassing: step 3, image 1 of 1
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
  4. Smart Parts Ion Battery Replacement: step 4, image 1 of 1
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
  5. Smart Parts Ion Battery Replacement, Grip: step 5, image 1 of 1
    • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
  6. Smart Parts Ion Battery Replacement: step 6, image 1 of 1
    • Remove the grip by sliding it towards the front of the gun.
  7. Smart Parts Ion Battery Replacement, Battery: step 7, image 1 of 2 Smart Parts Ion Battery Replacement, Battery: step 7, image 2 of 2
    • Remove the 9V battery by unsnapping it.
Shane Villalpando
1,031 Reputation
10 Guides authored
Cal Poly, Team 8-42, Amido Winter 2015 Member of Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 2,088
