Smartab STJR700 Back Camera Lens Replacement
  1. Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: step 1, image 1 of 2 Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: step 1, image 2 of 2
    • First, use a screwdriver to remove the screws on the back cover of the Smartab.
    • Next, carefully remove the cover to reveal the inside of the tablet.
  2. Smartab STJR700 Back Camera Lens Replacement: step 2, image 1 of 3 Smartab STJR700 Back Camera Lens Replacement: step 2, image 2 of 3 Smartab STJR700 Back Camera Lens Replacement: step 2, image 3 of 3
    • When you open the tablet, you will see several components.
    • You will see that the camera is stabilized by screws. The digitizer is held in place using black tape.
    • When the black tape is peeled back, you will see that the digitizer is also connected to the motherboard.
  3. Smartab STJR700 Back Camera Lens Replacement: step 3, image 1 of 3 Smartab STJR700 Back Camera Lens Replacement: step 3, image 2 of 3 Smartab STJR700 Back Camera Lens Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use a screwdriver to unscrew the camera from the tablet.
    • Use tweezers to remove the digitizer from the hard drive.
    • After the digitizer is removed and the camera is unscrewed, remove them from the tablet.
    • Replace the old camera with a replacement camera by using a screwdriver. Replace the old digitizer with a replacement digitizer by using a soldering tool.
    • To replace the camera lens, start by removing the broken glass by using tweezers.
    • If the new lens has adhesive, make sure that all the old adhesive is removed from the frame so that the lens does not stick out, and so a tighter seal is formed.
    • Once the glass is removed, place the new camera lense by peeling off the upper film and align the glass with the ring.
Fatu Woodson
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 463
