Snowboard Binding Replacement
  1. Snowboard Binding Replacement, Binding: step 1, image 1 of 3 Snowboard Binding Replacement, Binding: step 1, image 2 of 3 Snowboard Binding Replacement, Binding: step 1, image 3 of 3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Replacement: step 2, image 1 of 2 Snowboard Binding Replacement: step 2, image 2 of 2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Replacement: step 3, image 1 of 2 Snowboard Binding Replacement: step 3, image 2 of 2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Replacement: step 4, image 1 of 3 Snowboard Binding Replacement: step 4, image 2 of 3 Snowboard Binding Replacement: step 4, image 3 of 3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
2 other people completed this guide.
Loren Sunding
118 Reputation
1 Guide authored
Cal Poly, Team 17-4, Forte Winter 2014 Member of Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 39
Past 30 Days: 145
All Time: 15,889
