Snowboard Traction Pad Replacement
  1. Snowboard Traction Pad Replacement, Traction Pad: step 1, image 1 of 2 Snowboard Traction Pad Replacement, Traction Pad: step 1, image 2 of 2
    • Use a plastic or metal scraper to remove the existing traction pad.
  2. Snowboard Traction Pad Replacement: step 2, image 1 of 3 Snowboard Traction Pad Replacement: step 2, image 2 of 3 Snowboard Traction Pad Replacement: step 2, image 3 of 3
    • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
    • Let the adhesive remover sit for a few minutes.
    • Wipe away the residue using a towel and water.
    • Dry the the surface where the new traction pad will be placed.
  3. Snowboard Traction Pad Replacement: step 3, image 1 of 3 Snowboard Traction Pad Replacement: step 3, image 2 of 3 Snowboard Traction Pad Replacement: step 3, image 3 of 3
    • Peel the back off of the new traction pad to reveal the adhesive.
    • When placed, the traction pad should be about an inch away from the rear binding.
    • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
    • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
    • Give the adhesive a minimum of 12 hours to dry before use.
Finish Line
Jacob Garcia
101 Reputation
1 Guide authored
Cal Poly, Team 17-4, Forte Winter 2014 Member of Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 3,604
