Introduction
This guide will be used to instruct a person how to replace the spring that controls the up and down motion of the carbonation button should it become worn over time.
Press in the two gray buttons found on either side, at the top of the machine.
Pull back on the cover until it releases from the device and pull the back off.
Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
Remove the spring located under the carbonation button.
Replace with the new spring, by lining it up and pushing it down.
5 other people completed this guide.
2 Guide Comments
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
