SodaStream Source Loader Tab Replacement
  1. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: step 1, image 3 of 3
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Loader Tab Replacement: step 2, image 1 of 2 SodaStream Source Loader Tab Replacement: step 2, image 2 of 2
    Tool used on this step:
    Phillips #1 Screwdriver
    $8.99
    Buy
  3. SodaStream Source Loader Tab Replacement: step 3, image 1 of 2 SodaStream Source Loader Tab Replacement: step 3, image 2 of 2
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Loader Tab Replacement: step 4, image 1 of 1
    $8.99
    Buy
  5. SodaStream Source Loader Tab Replacement: step 5, image 1 of 2 SodaStream Source Loader Tab Replacement: step 5, image 2 of 2
    Jimmy
    $7.95
    Buy
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: step 6, image 1 of 3 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: step 6, image 2 of 3 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: step 6, image 3 of 3
    • Push the brass bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
  7. SodaStream Source Loader Tab Replacement: step 7, image 1 of 3 SodaStream Source Loader Tab Replacement: step 7, image 2 of 3 SodaStream Source Loader Tab Replacement: step 7, image 3 of 3
    • Slide the yellow battery cover up and away to remove it from the device.
  8. SodaStream Source Loader Tab Replacement: step 8, image 1 of 2 SodaStream Source Loader Tab Replacement: step 8, image 2 of 2
    • Unhook the bottom piece of the plastic arm on each side of the device.
  9. SodaStream Source Loader Tab Replacement: step 9, image 1 of 2 SodaStream Source Loader Tab Replacement: step 9, image 2 of 2
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
  10. SodaStream Source Loader Tab Replacement: step 10, image 1 of 2 SodaStream Source Loader Tab Replacement: step 10, image 2 of 2
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
  11. SodaStream Source Loader Tab Replacement: step 11, image 1 of 2 SodaStream Source Loader Tab Replacement: step 11, image 2 of 2
    • Remove the plastic oval and the spring within it.
  12. SodaStream Source Loader Tab Replacement: step 12, image 1 of 2 SodaStream Source Loader Tab Replacement: step 12, image 2 of 2
    • Pull the loader tab cover down and away from the rest of the carbonating block.
  13. SodaStream Source Loader Tab Replacement: step 13, image 1 of 1
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
  14. SodaStream Source Loader Tab Replacement: step 14, image 1 of 2 SodaStream Source Loader Tab Replacement: step 14, image 2 of 2
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
  15. SodaStream Source Loader Tab Replacement: step 15, image 1 of 3 SodaStream Source Loader Tab Replacement: step 15, image 2 of 3 SodaStream Source Loader Tab Replacement: step 15, image 3 of 3
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
  16. SodaStream Source Loader Tab Replacement: step 16, image 1 of 2 SodaStream Source Loader Tab Replacement: step 16, image 2 of 2
    • Unhook the silver spring arms on both sides of the device by pushing down.
  17. SodaStream Source Loader Tab Replacement: step 17, image 1 of 1
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
  18. SodaStream Source Loader Tab Replacement: step 18, image 1 of 3 SodaStream Source Loader Tab Replacement: step 18, image 2 of 3 SodaStream Source Loader Tab Replacement: step 18, image 3 of 3
    • Pull the foam pad up and remove it from the front side of the carbonation component.
  19. SodaStream Source Loader Tab Replacement: step 19, image 1 of 1
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
  20. SodaStream Source Loader Tab Replacement: step 20, image 1 of 3 SodaStream Source Loader Tab Replacement: step 20, image 2 of 3 SodaStream Source Loader Tab Replacement: step 20, image 3 of 3
    • Pull the loader tab out of the nozzle.
  21. SodaStream Source Loader Tab Replacement, Loader Tab: step 21, image 1 of 3 SodaStream Source Loader Tab Replacement, Loader Tab: step 21, image 2 of 3 SodaStream Source Loader Tab Replacement, Loader Tab: step 21, image 3 of 3
    • Pull the small inner plastic circle out of the large plastic loader tab piece.
8 other people completed this guide.
Angela Mossgrove
1,144 Reputation
3 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
41 Guides authored
6 Guide Comments
Thank you SO much for this! I was having a lot of trouble with this thing not releasing the bottle, so I disassembled it all and put it back together and now it works a treat! Not sure what was going on but I am so excited. You weren’t kidding at the end about it all falling apart… took ages to work out how it all went back together, but now I understand it and I have a working SodaStream. 5*!
Amanda L - Reply
Do you know where the tiny magnet goes? It fell out on the table as I was disassembling.
cheryl meeks - Reply
I think it has something to do with the microchip for the LED’s. Can’t figure out how else the light would light. I haven’t taken it apart far enough to find the magnet. Hope this helps you.
Paul Bibeau -
You can see the magnet in step 18, the first picture. Its right below where a screw used to be.
Tom Green -
I placed sodastream on side and removed top half. I could then see where parts needed to be after they “fell out” for reassembly. More pictures of those steps would be helpful. Thank
Past 24 Hours: 11
Past 7 Days: 102
Past 30 Days: 362
All Time: 27,765
