SodaStream Source Microchip Replacement
  1. SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: step 1, image 3 of 3
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Microchip Replacement: step 2, image 1 of 2 SodaStream Source Microchip Replacement: step 2, image 2 of 2
    Tool used on this step:
    Phillips #1 Screwdriver
    $8.99
    Buy
  3. SodaStream Source Microchip Replacement: step 3, image 1 of 2 SodaStream Source Microchip Replacement: step 3, image 2 of 2
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Microchip Replacement: step 4, image 1 of 1
    $8.99
    Buy
  5. SodaStream Source Microchip Replacement: step 5, image 1 of 2 SodaStream Source Microchip Replacement: step 5, image 2 of 2
    Jimmy
    $7.95
    Buy
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Microchip Replacement, Microchip: step 6, image 1 of 1
    • Remove the 9.1 mm screw from the microchip.
  7. SodaStream Source Microchip Replacement: step 7, image 1 of 3 SodaStream Source Microchip Replacement: step 7, image 2 of 3 SodaStream Source Microchip Replacement: step 7, image 3 of 3
    • Wedge the plastic spudger between the microchip and the glue dot until the glue pops off.
  8. SodaStream Source Microchip Replacement: step 8, image 1 of 3 SodaStream Source Microchip Replacement: step 8, image 2 of 3 SodaStream Source Microchip Replacement: step 8, image 3 of 3
    Spudger
    $2.99
    Buy
    • Use the spudger to lift the edge of the wire and pull the wire out of the microchip.
    • Use an ESD tool such as a nylon spudger when working with potentially dangerous electronics.
    • While reconnecting the wires, you will need a hot glue gun to reattach the wire ends to the new chip.
Angela Mossgrove
1,144 Reputation
3 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
41 Guides authored
4 Guide Comments
Great information, but is there someone out there offering this repair as a service, I’m not motivated enough to do this myself and happy to pay someone to do it for me
matteo barnett - Reply
Where can you buy the microchip please?
Jill - Reply
Where can you purchase a replacement microchip from?
David Grosz - Reply
Where can I find the reassemble source at
mcphersonp411 - Reply
Past 24 Hours: 8
Past 7 Days: 48
Past 30 Days: 156
All Time: 5,437
