Soehnle Exacta scale display no longer shows anything
  1. Soehnle Exacta scale display no longer shows anything, Remove the cover: step 1, image 1 of 3 Soehnle Exacta scale display no longer shows anything, Remove the cover: step 1, image 2 of 3 Soehnle Exacta scale display no longer shows anything, Remove the cover: step 1, image 3 of 3
    • Remove the two Phillips screws (red) under the display area.
    • Release the four clips (green) on the sides (push to the side with a flat-blade screwdriver)
    • Then lift off the cover with the contacts for measuring the body fat
  2. Soehnle Exacta scale display no longer shows anything, Detach and clean the display: step 2, image 1 of 2 Soehnle Exacta scale display no longer shows anything, Detach and clean the display: step 2, image 2 of 2
    • If only the kick buttons are involved, this step will not be necessary.
    • Remove the two screws holding the circuit board (yellow). The circuit board can now be lifted off.
    • Remove the 6 screws (green) holding the display and simply lift off the display.
    • The contacts can now be cleaned
    • The kick switch, which turns the display on, is located on the blue cable
  3. Soehnle Exacta scale display no longer shows anything, Opening the metal housing: step 3, image 1 of 2 Soehnle Exacta scale display no longer shows anything, Opening the metal housing: step 3, image 2 of 2
    • Unhook the two springs from the hooks
    • The metal cover can now be lifted off
  4. Soehnle Exacta scale display no longer shows anything, Checking the kick switch: step 4, image 1 of 1
    • Check the two kick switches connected to the blue cable (blue boxes), e.g. by simply short-circuiting the connection on the circuit board (red arrow) (with the battery connected). If the display then shows something, the problem has been found.
    • In my case, I had to bent the two contact lugs a little (one broke off - but the other seems to be sufficient)
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Peter Scholl
1,440 Reputation
6 Guides authored
AEG-Make&Repair AG Member of AEG-Make&Repair AG
Local Repair Groups
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 78
All Time: 582
