Sol Republic Deck Battery Replacement
  1. Sol Republic Deck Battery Replacement, Battery: step 1, image 1 of 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Battery Replacement: step 2, image 1 of 1
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Battery Replacement: step 3, image 1 of 1
    • Remove ribbon cable from the circuit board.
  4. Sol Republic Deck Battery Replacement: step 4, image 1 of 2 Sol Republic Deck Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
    • The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
    • Melt the solder with an iron and used the tweezers to pull the wire upright.
    • You can pull the circuit board up and away from the wires once the wires are pointed up.
  5. Sol Republic Deck Battery Replacement: step 5, image 1 of 1
    • Unscrew eighteen 6.2 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Battery Replacement: step 6, image 1 of 3 Sol Republic Deck Battery Replacement: step 6, image 2 of 3 Sol Republic Deck Battery Replacement: step 6, image 3 of 3
    • Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
    • Remove the battery from the battery case.
    • Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
5 other people completed this guide.
Ross Bolton
139 Reputation
1 Guide authored
IUPUI, Team S3-G1, Baechle Spring 2017 Member of IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 Members
3 Guides authored
10 Guide Comments
I appreciate the battery replacement for the deck,but what about battery replacement
For the deck ultra
chai4i - Reply
What type of battery is it?
Peter Perez - Reply
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - Reply
The wires which are blue and purple are connected to battery body if im not wrong
vineeth m -
After changing the battery my device is not switching on. Please help. I connected the charger the battery is charging... showing red.
vineeth m - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 42
All Time: 9,035
