Sol Republic Deck Bluetooth Button Replacement
  1. Sol Republic Deck Bluetooth Button Replacement, Bluetooth Button: step 1, image 1 of 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Bluetooth Button Replacement: step 2, image 1 of 1
    • Use the screwdriver to unscrew two 3.6mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Bluetooth Button Replacement: step 3, image 1 of 1
    • Remove the ribbon cable from the circuit board.
  4. Sol Republic Deck Bluetooth Button Replacement: step 4, image 1 of 1
    • Plug in de-soldering kit and wait 3 minutes for the solder to heat up.
    • Use the tip of your soldering iron to heat the old solder unit and apply until it melts.
    • Remove speaker wires connecting the speaker to the circuit board.
  5. Sol Republic Deck Bluetooth Button Replacement: step 5, image 1 of 1
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
  6. Sol Republic Deck Bluetooth Button Replacement: step 6, image 1 of 1
    • Unscrew fifteen 6.2mm Phillips #0 screws and lift the black plastic plate from the case.
  7. Sol Republic Deck Bluetooth Button Replacement: step 7, image 1 of 2 Sol Republic Deck Bluetooth Button Replacement: step 7, image 2 of 2
    • Remove the three 3.6mm Phillips #0 screws.
    • Remove the circuit board containing the BlueTooth button.
Jonathan Holtman
368 Reputation
2 Guides authored
IUPUI, Team S3-G1, Baechle Spring 2017 Member of IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 561
