Sol Republic Deck Speaker Replacement
  1. Sol Republic Deck Speaker Replacement, Speaker: step 1, image 1 of 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Speaker Replacement: step 2, image 1 of 1
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Speaker Replacement: step 3, image 1 of 1
    • Unplug the ribbon cable from the port.
  4. Sol Republic Deck Speaker Replacement: step 4, image 1 of 1
    • Unscrew 5 3.63 mm Phillips #0 screws securing the circuit board.
  5. Sol Republic Deck Speaker Replacement: step 5, image 1 of 1
    • Unscrew 15 6.15 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Speaker Replacement: step 6, image 1 of 1
    • Remove 4 3.63 mm Phillips #0 screws holding the bracket.
  7. Sol Republic Deck Speaker Replacement: step 7, image 1 of 1
    • Use the hairdryer to soften the glue holding the speaker to the plastic plate.
  8. Sol Republic Deck Speaker Replacement: step 8, image 1 of 1
    • Gently pull up on the speaker.
2 other people completed this guide.
Jonathan Holtman
368 Reputation
2 Guides authored
IUPUI, Team S3-G1, Baechle Spring 2017 Member of IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 2,155
