Solio CLASSIC2 USB Port Replacement
  1. Solio CLASSIC2 USB Port Replacement, Disconnecting the Battery: step 1, image 1 of 1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 USB Port Replacement: step 2, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 USB Port Replacement: step 3, image 1 of 3 Solio CLASSIC2 USB Port Replacement: step 3, image 2 of 3 Solio CLASSIC2 USB Port Replacement: step 3, image 3 of 3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 USB Port Replacement: step 4, image 1 of 2 Solio CLASSIC2 USB Port Replacement: step 4, image 2 of 2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 USB Port Replacement: step 5, image 1 of 2 Solio CLASSIC2 USB Port Replacement: step 5, image 2 of 2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 USB Port Replacement: step 6, image 1 of 2 Solio CLASSIC2 USB Port Replacement: step 6, image 2 of 2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 USB Port Replacement, Circuit Board: step 7, image 1 of 1
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 USB Port Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
  9. Solio CLASSIC2 USB Port Replacement, USB Port: step 9, image 1 of 1
    • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
    • Remove solder from both spots on outside of the USB port.
    • Remove solder from base of the USB port.
Anthony Ramos
102 Reputation
1 Guide authored
Cal Poly, Team 4-28, Amido Fall 2013 Member of Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,138
