Solio Rocsta Internal Components Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Solio Rocsta Internal Components Replacement, Internal Components: step 1, image 1 of 1
    • Remove the three 7mm Torx T7 screws.
  2. Solio Rocsta Internal Components Replacement: step 2, image 1 of 3 Solio Rocsta Internal Components Replacement: step 2, image 2 of 3 Solio Rocsta Internal Components Replacement: step 2, image 3 of 3
    • Insert the flat end of the spudger between the top panel and the body.
    • Use the spudger as a lever to carefully pry apart the two panels.
    • As you pry, take care not to break the small orange clip holding the top to the body.
    • Lift the panel above and away to disconnect the panel from the body.
    • Be careful when lifting because you could break the wiring connecting the motherboard to the panel.
  3. Solio Rocsta Internal Components Replacement: step 3, image 1 of 2 Solio Rocsta Internal Components Replacement: step 3, image 2 of 2
    • Lift the panel off the body and set it next to the device.
    • Remember to use caution when lifting because you could break the wiring connecting the motherboard to the panel.
  4. Solio Rocsta Internal Components Replacement: step 4, image 1 of 1
    • Remove the two 6mm Torx T6 screws from the motherboard.
  5. Solio Rocsta Internal Components Replacement: step 5, image 1 of 2 Solio Rocsta Internal Components Replacement: step 5, image 2 of 2
    • Lift the end of the USB cord out of the body.
    • The cord fits over an orange peg.
  6. Solio Rocsta Internal Components Replacement: step 6, image 1 of 3 Solio Rocsta Internal Components Replacement: step 6, image 2 of 3 Solio Rocsta Internal Components Replacement: step 6, image 3 of 3
    • Lift up the battery with your fingers or with the flat end of the spudger.
    • Be prepared to use force because the battery is adhered to the body.
    • Do not try to remove the battery completely because the wiring connects to the motherboard.
  7. Solio Rocsta Internal Components Replacement: step 7, image 1 of 2 Solio Rocsta Internal Components Replacement: step 7, image 2 of 2
    • Remove the battery and the motherboard from the body.
Aimee Whiteside
1 Reputation
1 Guide authored
iFixit, Team 1-1, Goldberg SU 2015 Member of iFixit, Team 1-1, Goldberg SU 2015
FIX-GOLDBERG-SU15S1G1
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 90
