Solio Rocsta LED Replacement
  1. Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: step 1, image 1 of 2 Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: step 1, image 2 of 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta LED Replacement: step 2, image 1 of 2 Solio Rocsta LED Replacement: step 2, image 2 of 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  3. Solio Rocsta LED Replacement, Battery: step 3, image 1 of 1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta LED Replacement: step 4, image 1 of 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
  5. Solio Rocsta LED Replacement: step 5, image 1 of 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta LED Replacement, LED: step 6, image 1 of 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case.
  7. Solio Rocsta LED Replacement: step 7, image 1 of 1
    • Flip the circuit board to be able to see where the LEDs are soldered to.
    • With a Soldering Iron, desolder the LEDs’ connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
  8. Solio Rocsta LED Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Gently pry the LEDs using one of the Precision Tweezers.
David Vazquez
577 Reputation
5 Guides authored
USF Tampa, Team S13-G13, Cagle Fall 2017 Member of USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 132
