Sonos Connect WIFI Card Replacement
  1. Sonos Connect WIFI Card Replacement, WIFI Card: step 1, image 1 of 3 Sonos Connect WIFI Card Replacement, WIFI Card: step 1, image 2 of 3 Sonos Connect WIFI Card Replacement, WIFI Card: step 1, image 3 of 3
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Sonos Connect WIFI Card Replacement: step 2, image 1 of 3 Sonos Connect WIFI Card Replacement: step 2, image 2 of 3 Sonos Connect WIFI Card Replacement: step 2, image 3 of 3
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Sonos Connect WIFI Card Replacement: step 3, image 1 of 3 Sonos Connect WIFI Card Replacement: step 3, image 2 of 3 Sonos Connect WIFI Card Replacement: step 3, image 3 of 3
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Sonos Connect WIFI Card Replacement: step 4, image 1 of 2 Sonos Connect WIFI Card Replacement: step 4, image 2 of 2
    • Remove the connection for the front buttons to fully remove the cover.
  5. Sonos Connect WIFI Card Replacement: step 5, image 1 of 2 Sonos Connect WIFI Card Replacement: step 5, image 2 of 2
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Sonos Connect WIFI Card Replacement: step 6, image 1 of 2 Sonos Connect WIFI Card Replacement: step 6, image 2 of 2
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Sonos Connect WIFI Card Replacement: step 7, image 1 of 3 Sonos Connect WIFI Card Replacement: step 7, image 2 of 3 Sonos Connect WIFI Card Replacement: step 7, image 3 of 3
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
Clark Snyder
483 Reputation
4 Guides authored
IUPUI, Team 3-2, Baechle Spring 2016 Member of IUPUI, Team 3-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G2
4 Members
4 Guides authored
3 Comments
Where do you source the replacement wifi card?
cterrell9 - Reply
great piece of advice. After some searching I found this on ebay.
https://www.ebay.co.uk/itm/Atheros-AR500...
or type in search bar Atheros AR5008 AR5416 Mini PCI N 802.11N 300M WIFI Wireless Card Dell ASUS SONY.
It cost me around £10.00 and seems to be working fine now after installation
Garry Briggs - Reply
Do you know the wireless card for the sonos connect s15?
Craig Wojay - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 58
All Time: 6,121
