Sonos One Control Panel & Microphone Replacement
  1. Sonos One Control Panel & Microphone Replacement, Protective Cover: step 1, image 1 of 3 Sonos One Control Panel & Microphone Replacement, Protective Cover: step 1, image 2 of 3 Sonos One Control Panel & Microphone Replacement, Protective Cover: step 1, image 3 of 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Control Panel & Microphone Replacement: step 2, image 1 of 3 Sonos One Control Panel & Microphone Replacement: step 2, image 2 of 3 Sonos One Control Panel & Microphone Replacement: step 2, image 3 of 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Control Panel & Microphone Replacement: step 3, image 1 of 2 Sonos One Control Panel & Microphone Replacement: step 3, image 2 of 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Control Panel & Microphone Replacement: step 4, image 1 of 3 Sonos One Control Panel & Microphone Replacement: step 4, image 2 of 3 Sonos One Control Panel & Microphone Replacement: step 4, image 3 of 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Control Panel & Microphone Replacement: step 5, image 1 of 2 Sonos One Control Panel & Microphone Replacement: step 5, image 2 of 2
    • Slide the protective cover upwards to remove.
  6. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: step 6, image 1 of 3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: step 6, image 2 of 3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: step 6, image 3 of 3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Control Panel & Microphone Replacement: step 7, image 1 of 2 Sonos One Control Panel & Microphone Replacement: step 7, image 2 of 2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Control Panel & Microphone Replacement: step 8, image 1 of 3 Sonos One Control Panel & Microphone Replacement: step 8, image 2 of 3 Sonos One Control Panel & Microphone Replacement: step 8, image 3 of 3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Control Panel & Microphone Replacement: step 9, image 1 of 2 Sonos One Control Panel & Microphone Replacement: step 9, image 2 of 2
    • Pull the control panel away from the speaker to separate.
3 other people completed this guide.
Marcus Glowa
1,064 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2018 Member of USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Members
14 Guides authored
1 Guide Comment
where can I buy a replacement control panel?
Chris Myers - Reply
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 87
All Time: 7,772
