Sonos One Power Adapter Replacement
  1. Sonos One Power Adapter Replacement, Protective Cover: step 1, image 1 of 3 Sonos One Power Adapter Replacement, Protective Cover: step 1, image 2 of 3 Sonos One Power Adapter Replacement, Protective Cover: step 1, image 3 of 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Power Adapter Replacement: step 2, image 1 of 3 Sonos One Power Adapter Replacement: step 2, image 2 of 3 Sonos One Power Adapter Replacement: step 2, image 3 of 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Power Adapter Replacement: step 3, image 1 of 2 Sonos One Power Adapter Replacement: step 3, image 2 of 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Power Adapter Replacement: step 4, image 1 of 3 Sonos One Power Adapter Replacement: step 4, image 2 of 3 Sonos One Power Adapter Replacement: step 4, image 3 of 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Power Adapter Replacement: step 5, image 1 of 2 Sonos One Power Adapter Replacement: step 5, image 2 of 2
    • Slide the protective cover upwards to remove.
  6. Sonos One Power Adapter Replacement, Control Panel & Microphone: step 6, image 1 of 3 Sonos One Power Adapter Replacement, Control Panel & Microphone: step 6, image 2 of 3 Sonos One Power Adapter Replacement, Control Panel & Microphone: step 6, image 3 of 3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Power Adapter Replacement: step 7, image 1 of 2 Sonos One Power Adapter Replacement: step 7, image 2 of 2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Power Adapter Replacement: step 8, image 1 of 3 Sonos One Power Adapter Replacement: step 8, image 2 of 3 Sonos One Power Adapter Replacement: step 8, image 3 of 3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Power Adapter Replacement: step 9, image 1 of 2 Sonos One Power Adapter Replacement: step 9, image 2 of 2
    • Pull the control panel away from the speaker to separate.
  10. Sonos One Power Adapter Replacement, Power Adapter Receptacle: step 10, image 1 of 3 Sonos One Power Adapter Replacement, Power Adapter Receptacle: step 10, image 2 of 3 Sonos One Power Adapter Replacement, Power Adapter Receptacle: step 10, image 3 of 3
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
  11. Sonos One Power Adapter Replacement: step 11, image 1 of 2 Sonos One Power Adapter Replacement: step 11, image 2 of 2
    • Using a plastic opening tool, separate the motherboard from the speaker.
  12. Sonos One Power Adapter Replacement: step 12, image 1 of 3 Sonos One Power Adapter Replacement: step 12, image 2 of 3 Sonos One Power Adapter Replacement: step 12, image 3 of 3
    • Using your thumb, disconnect the speaker cable from the motherboard.
  13. Sonos One Power Adapter Replacement: step 13, image 1 of 3 Sonos One Power Adapter Replacement: step 13, image 2 of 3 Sonos One Power Adapter Replacement: step 13, image 3 of 3
    • Disconnect the power adapter plug from the motherboard using your thumb.
  14. Sonos One Power Adapter Replacement: step 14, image 1 of 3 Sonos One Power Adapter Replacement: step 14, image 2 of 3 Sonos One Power Adapter Replacement: step 14, image 3 of 3
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
  15. Sonos One Power Adapter Replacement: step 15, image 1 of 2 Sonos One Power Adapter Replacement: step 15, image 2 of 2
    • Remove the motherboard panel from the speaker housing.
  16. Sonos One Power Adapter Replacement: step 16, image 1 of 3 Sonos One Power Adapter Replacement: step 16, image 2 of 3 Sonos One Power Adapter Replacement: step 16, image 3 of 3
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
8 other people completed this guide.
Marcus Glowa
1,082 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2018 Member of USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 129
All Time: 9,502
