Sonos One Protective Cover Replacement
Marcus Glowa
Marcus Glowa and 3 other contributors
Last updated on May 21, 2023
2 minutes
Easy
Introduction
Go to step 1
This guide is for the replacement of the metal housing for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
Parts
Tools
Show more…
  1. Sonos One Protective Cover Replacement, Protective Cover: step 1, image 1 of 3 Sonos One Protective Cover Replacement, Protective Cover: step 1, image 2 of 3 Sonos One Protective Cover Replacement, Protective Cover: step 1, image 3 of 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: step 2, image 1 of 3 Sonos One Protective Cover Replacement: step 2, image 2 of 3 Sonos One Protective Cover Replacement: step 2, image 3 of 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    More specifics on the four 10mm Torx T10 screws at the bottom, step 2.
    ex: M3
    Thanks
    J Pappas - Reply
  3. Sonos One Protective Cover Replacement: step 3, image 1 of 2 Sonos One Protective Cover Replacement: step 3, image 2 of 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: step 4, image 1 of 3 Sonos One Protective Cover Replacement: step 4, image 2 of 3 Sonos One Protective Cover Replacement: step 4, image 3 of 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: step 5, image 1 of 2 Sonos One Protective Cover Replacement: step 5, image 2 of 2
    • Slide the protective cover upwards to remove.
4 other people completed this guide.
Marcus Glowa
1,046 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2018 Member of USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Members
6 Guides authored
One Comment
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 5,321
