Sonos Roam Large Ribbon Replacement
  1. Sonos Roam Large Ribbon Replacement, End Caps: step 1, image 1 of 3 Sonos Roam Large Ribbon Replacement, End Caps: step 1, image 2 of 3 Sonos Roam Large Ribbon Replacement, End Caps: step 1, image 3 of 3
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Large Ribbon Replacement: step 2, image 1 of 2 Sonos Roam Large Ribbon Replacement: step 2, image 2 of 2
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Large Ribbon Replacement, Speaker Grille: step 3, image 1 of 2 Sonos Roam Large Ribbon Replacement, Speaker Grille: step 3, image 2 of 2
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Large Ribbon Replacement: step 4, image 1 of 2 Sonos Roam Large Ribbon Replacement: step 4, image 2 of 2
    • Flip the device.
  5. Sonos Roam Large Ribbon Replacement: step 5, image 1 of 3 Sonos Roam Large Ribbon Replacement: step 5, image 2 of 3 Sonos Roam Large Ribbon Replacement: step 5, image 3 of 3
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Large Ribbon Replacement, Speaker Module: step 6, image 1 of 2 Sonos Roam Large Ribbon Replacement, Speaker Module: step 6, image 2 of 2
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Large Ribbon Replacement: step 7, image 1 of 3 Sonos Roam Large Ribbon Replacement: step 7, image 2 of 3 Sonos Roam Large Ribbon Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Large Ribbon Replacement, Outer Circuit Board: step 8, image 1 of 2 Sonos Roam Large Ribbon Replacement, Outer Circuit Board: step 8, image 2 of 2
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Large Ribbon Replacement: step 9, image 1 of 3 Sonos Roam Large Ribbon Replacement: step 9, image 2 of 3 Sonos Roam Large Ribbon Replacement: step 9, image 3 of 3
    Buy
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
  10. Sonos Roam Large Ribbon Replacement: step 10, image 1 of 3 Sonos Roam Large Ribbon Replacement: step 10, image 2 of 3 Sonos Roam Large Ribbon Replacement: step 10, image 3 of 3
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Large Ribbon Replacement: step 11, image 1 of 2 Sonos Roam Large Ribbon Replacement: step 11, image 2 of 2
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
  12. Sonos Roam Large Ribbon Replacement, Battery: step 12, image 1 of 2 Sonos Roam Large Ribbon Replacement, Battery: step 12, image 2 of 2
  13. Sonos Roam Large Ribbon Replacement: step 13, image 1 of 2 Sonos Roam Large Ribbon Replacement: step 13, image 2 of 2
    Buy
    • Use the tweezers to firmly squeeze the middle of the plug.
    • Pull the plug out to remove it from its socket.
    • Remove the battery from the device.
  14. Sonos Roam Large Ribbon Replacement: step 14, image 1 of 3 Sonos Roam Large Ribbon Replacement: step 14, image 2 of 3 Sonos Roam Large Ribbon Replacement: step 14, image 3 of 3
    • Use the iFixit opening tool to pry the battery out of its casing.
    • Use the iOpener, blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  15. Sonos Roam Large Ribbon Replacement: step 15, image 1 of 1
    • Remove the battery from its casing.
  16. Sonos Roam Large Ribbon Replacement, Inner Circuit Board: step 16, image 1 of 2 Sonos Roam Large Ribbon Replacement, Inner Circuit Board: step 16, image 2 of 2
    • Use the TR9 Torx screwdriver to remove the two 5 mm screws.
  17. Sonos Roam Large Ribbon Replacement: step 17, image 1 of 3 Sonos Roam Large Ribbon Replacement: step 17, image 2 of 3 Sonos Roam Large Ribbon Replacement: step 17, image 3 of 3
    Buy
    • Use the tweezers to firmly squeeze the center of the plug.
    • Grab the metal box to remove the inner circuit board.
  18. Sonos Roam Large Ribbon Replacement, Large Ribbon: step 18, image 1 of 3 Sonos Roam Large Ribbon Replacement, Large Ribbon: step 18, image 2 of 3 Sonos Roam Large Ribbon Replacement, Large Ribbon: step 18, image 3 of 3
    Buy
    • Flip the inner circuit board around so the button and USB-C port are facing upward.
    • Use the tweezers to flip the large ribbon latch up.
    • Pull the large ribbon away from the inner circuit board to remove it.
Lauren Young
614 Reputation
5 Guides authored
2 Comments
Replace the ribbon or reposition it?
Sabin Oana - Reply
So where do we purchase the Sonos Roam Large Ribbon to replace it?!
MareBear - Reply
Past 24 Hours: 4
Past 7 Days: 52
Past 30 Days: 203
All Time: 1,172
