Sony α6500 Lens Mount Replacement
  1. Sony α6500 Lens Mount Replacement, Lens Mount: step 1, image 1 of 2 Sony α6500 Lens Mount Replacement, Lens Mount: step 1, image 2 of 2
    • Use a screwdriver to remove four 5mm JIS 00 screws from the lens mount.
  2. Sony α6500 Lens Mount Replacement: step 2, image 1 of 2 Sony α6500 Lens Mount Replacement: step 2, image 2 of 2
    • Pull the lens mount off by gently wiggling it until it comes loose.
    • It is difficult to slide the mount off the metal pin sticking through the lower left side. Pull it off from where the pin is if it gets stuck.
  3. Sony α6500 Lens Mount Replacement: step 3, image 1 of 1
    • Remove the metal ring underneath the lens mount.
    • When replacing the ring, line up the two holes in the ring with the two pins on either side of the mount.
2 other people completed this guide.
Jackson Furie
807 Reputation
5 Guides authored
Cal Poly, Team S11-G5, Regan Fall 2019 Member of Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 971
