Sony AZ1VR LCD Side Display Replacement
  1. Sony AZ1VR LCD Side Display Replacement, LCD Side Display: step 1, image 1 of 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: step 1, image 2 of 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: step 1, image 3 of 3
    • Remove the two screws on the bottom of the camera.
    • Remove the screw inside the battery door.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
  2. Sony AZ1VR LCD Side Display Replacement: step 2, image 1 of 3 Sony AZ1VR LCD Side Display Replacement: step 2, image 2 of 3 Sony AZ1VR LCD Side Display Replacement: step 2, image 3 of 3
    • Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
  3. Sony AZ1VR LCD Side Display Replacement: step 3, image 1 of 3 Sony AZ1VR LCD Side Display Replacement: step 3, image 2 of 3 Sony AZ1VR LCD Side Display Replacement: step 3, image 3 of 3
    • Remove the screws connected to the silver metal plate.
    • Remove the plate by pulling the back up and pushing it towards the front.
    • Remove the screw directly above the LCD display.
    • Pull the plastic up gently, it will be connected by cables on the bottom.
    • Disconnect the cable going to the LCD display.
Michael Martin
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 10
All Time: 233
