Introduction
Is your battery door damaged or is the clasp broken?
To access the battery, first make sure the camera is out of the case.
Push down on the door lock, located on the rear of the action cam.
Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
Remove the circled 4 millimeter black screw adjacent to where the door is attached.
Almost done!
