Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: step 1, image 1 of 2 Sony Alpha 5100 Front Plate Replacement, Battery: step 1, image 2 of 2
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: step 2, image 1 of 1
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: step 3, image 1 of 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: step 3, image 2 of 3 Sony Alpha 5100 Front Plate Replacement, Front Plate: step 3, image 3 of 3
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: step 4, image 1 of 2 Sony Alpha 5100 Front Plate Replacement: step 4, image 2 of 2
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
  5. Sony Alpha 5100 Front Plate Replacement: step 5, image 1 of 2 Sony Alpha 5100 Front Plate Replacement: step 5, image 2 of 2
    • Use the opening tool to gently pop the front plate apart from the body.
Kevin Raggiani
444 Reputation
3 Guides authored
2 Comments
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - Reply
Step 4 is missing one screw. Pop the flash and there is a screw there sideways that must come out.
Nick P - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 35
All Time: 1,309
