Sony Alpha 6000 Lens Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sony Alpha 6000 Lens Replacement, Battery: step 1, image 1 of 1
    • Make sure the camera is turned off by turning the switch to OFF.
  2. Sony Alpha 6000 Lens Replacement: step 2, image 1 of 1
    • Flip the camera around to access the battery compartment.
    • Slide the battery compartment lock to the left to unlock it.
  3. Sony Alpha 6000 Lens Replacement: step 3, image 1 of 1
    • Locate the blue latch that holds the battery in.
  4. Sony Alpha 6000 Lens Replacement: step 4, image 1 of 1
    • Push the latch back to release battery.
  5. Sony Alpha 6000 Lens Replacement: step 5, image 1 of 1
    • The battery can now be taken out of its compartment.
  6. Sony Alpha 6000 Lens Replacement, Lens: step 6, image 1 of 1
    • Press and hold the release button next to the lens on the front of the camera.
  7. Sony Alpha 6000 Lens Replacement: step 7, image 1 of 1
    • While holding the release button, twist the lens counterclockwise and pull it off.
Jennifer Vuu
548 Reputation
3 Guides authored
USF Tampa, Team 4-5, Passmore Fall 2016 Member of USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 613
