Sony Alpha 6000 Shutter Button Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sony Alpha 6000 Shutter Button Replacement, Battery: step 1, image 1 of 1
    • Make sure the camera is turned off by turning the switch to OFF.
  2. Sony Alpha 6000 Shutter Button Replacement: step 2, image 1 of 1
    • Flip the camera around to access the battery compartment.
    • Slide the battery compartment lock to the left to unlock it.
  3. Sony Alpha 6000 Shutter Button Replacement: step 3, image 1 of 1
    • Locate the blue latch that holds the battery in.
  4. Sony Alpha 6000 Shutter Button Replacement: step 4, image 1 of 1
    • Push the latch back to release battery.
  5. Sony Alpha 6000 Shutter Button Replacement: step 5, image 1 of 1
    • The battery can now be taken out of its compartment.
  6. Sony Alpha 6000 Shutter Button Replacement, Back Cover: step 6, image 1 of 1
    • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
  7. Sony Alpha 6000 Shutter Button Replacement: step 7, image 1 of 1
    • Turn the camera sideways.
    • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
    • Unscrew using the J00 head screw.
  8. Sony Alpha 6000 Shutter Button Replacement: step 8, image 1 of 1
    • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
  9. Sony Alpha 6000 Shutter Button Replacement: step 9, image 1 of 1
    • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
    • Locate them and unscrew them.
  10. Sony Alpha 6000 Shutter Button Replacement: step 10, image 1 of 2 Sony Alpha 6000 Shutter Button Replacement: step 10, image 2 of 2
    • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
    • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
  11. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: step 11, image 1 of 1
    • Once the back cover is off, locate the flash of the camera and push it forward to open it
  12. Sony Alpha 6000 Shutter Button Replacement: step 12, image 1 of 1
    • Locate the two 3 mm screws within the flash and unscrew them
  13. Sony Alpha 6000 Shutter Button Replacement: step 13, image 1 of 1
    • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
  14. Sony Alpha 6000 Shutter Button Replacement: step 14, image 1 of 2 Sony Alpha 6000 Shutter Button Replacement: step 14, image 2 of 2
    • Hold the top of the camera away from the body.
    • Carefully turn it over to uncover the bottom of the shutter button.
  15. Sony Alpha 6000 Shutter Button Replacement: step 15, image 1 of 1
    • Locate the two screws holding the shutter button and unscrew them.
  16. Sony Alpha 6000 Shutter Button Replacement: step 16, image 1 of 1
    Tool used on this step:
    Buy
    • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
  17. Sony Alpha 6000 Shutter Button Replacement: step 17, image 1 of 1
    • Turn the top plastic piece back over.
    • Now you will be able to completely remove the camera's shutter button.
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
6 other people completed this guide.
Fernando Sierra
376 Reputation
2 Guides authored
USF Tampa, Team 4-5, Passmore Fall 2016 Member of USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Members
12 Guides authored
4 Guide Comments
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Reply
Where can i buy a replacement button?
Simon Lundh - Reply
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster -
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 159
All Time: 18,859
