Sony Alpha A350 Power Switch Replacement
  1. Sony Alpha A350 Power Switch Replacement, Power Switch: step 1, image 1 of 3 Sony Alpha A350 Power Switch Replacement, Power Switch: step 1, image 2 of 3 Sony Alpha A350 Power Switch Replacement, Power Switch: step 1, image 3 of 3
    • Identify and unscrew the ten PH000 screws around the top, front, left, and right sides of the camera body.
    • Screws are very small, can be difficult to remove, and easy to lose.
  2. Sony Alpha A350 Power Switch Replacement: step 2, image 1 of 3 Sony Alpha A350 Power Switch Replacement: step 2, image 2 of 3 Sony Alpha A350 Power Switch Replacement: step 2, image 3 of 3
    • Slowly separate the back case from the camera.
    • There may be a ribbon cable connecting the two pieces. Unlock the connector and remove the ribbon cable if necessary.
    • Idenify and unscrew the two PH000 screws connecting the power switch.
    • Remove the power switch.
Sydney Duncan
820 Reputation
5 Guides authored
CJLADIES Member of CJLADIES
Community
1 Member
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 23
All Time: 1,824
