Sony Alpha DSLR- A850 Viewfinder Window Replacement
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: step 1, image 1 of 1
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 2, image 1 of 1
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 3, image 1 of 1
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: step 4, image 1 of 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: step 4, image 2 of 2
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 5, image 1 of 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 6, image 1 of 1
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 791
