Sony Alpha ILCE-6000 E-mount Replacement
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: step 1, image 1 of 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: step 2, image 1 of 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: step 3, image 1 of 2 Sony Alpha ILCE-6000 E-mount Replacement: step 3, image 2 of 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: step 4, image 1 of 2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: step 4, image 2 of 2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: step 5, image 1 of 3 Sony Alpha ILCE-6000 E-mount Replacement: step 5, image 2 of 3 Sony Alpha ILCE-6000 E-mount Replacement: step 5, image 3 of 3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: step 6, image 1 of 3 Sony Alpha ILCE-6000 E-mount Replacement: step 6, image 2 of 3 Sony Alpha ILCE-6000 E-mount Replacement: step 6, image 3 of 3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: step 7, image 1 of 1
    • Replace the plastic E-mount ring with a new one.
Yirga Yilma
221 Reputation
2 Guides authored
UW Tacoma, Team 1-4, Rose Winter 2017 Member of UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Members
10 Guides authored
2 Comments
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Reply
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Reply
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 50
All Time: 3,742
