Sony Alpha NEX-6 Control Wheel Replacement
  1. Sony Alpha NEX-6 Control Wheel Replacement, Battery: step 1, image 1 of 1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 Control Wheel Replacement: step 2, image 1 of 1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 Control Wheel Replacement: step 3, image 1 of 1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
  4. Sony Alpha NEX-6 Control Wheel Replacement, Battery compartment screws: step 4, image 1 of 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
  5. Sony Alpha NEX-6 Control Wheel Replacement, Bottom screws: step 5, image 1 of 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
  6. Sony Alpha NEX-6 Control Wheel Replacement, Side screws: step 6, image 1 of 1
    • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
    • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
  7. Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: step 7, image 1 of 2 Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: step 7, image 2 of 2
    • Starting with the battery compartment gently begin to separate the back case front the camera.
    • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
    • Gently lift the back case away from the camera an slide it down to completely remove the back case.
  8. Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: step 8, image 1 of 2 Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: step 8, image 2 of 2
    • Pry out the ribbon cable by carefully pushing on its side tabs with a spudger.
  9. Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: step 9, image 1 of 2 Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Using a spudger, lift the metal locking tab located at the top right corner of control wheel assembly.
    • Using tweezers, carefully slide the assembly up to release it.
5 other people completed this guide.
Clayton Dale
1,067 Reputation
7 Guides authored
USF Tampa, Team 11-2, Blackwell Winter 2015 Member of USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 64
All Time: 5,569
