Sony Alpha NEX-C3 LCD Screen Replacement
  1. Sony Alpha NEX-C3 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Turn off the camera by sliding the power switch.
  2. Sony Alpha NEX-C3 LCD Screen Replacement: step 2, image 1 of 1
    • Tilt up the LCD screen.
  3. Sony Alpha NEX-C3 LCD Screen Replacement: step 3, image 1 of 1
    • Use a Phillips head 000 screwdriver to remove the two 2.0mm screws on the bottom of the LCD screen.
  4. Sony Alpha NEX-C3 LCD Screen Replacement: step 4, image 1 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 4, image 2 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 4, image 3 of 3
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the smaller backplate of the LCD screen that covers the ribbon cable.
    • The smaller backplate should easily come off. Put it to the side.
  5. Sony Alpha NEX-C3 LCD Screen Replacement: step 5, image 1 of 2 Sony Alpha NEX-C3 LCD Screen Replacement: step 5, image 2 of 2
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the bigger backplate of the LCD.
  6. Sony Alpha NEX-C3 LCD Screen Replacement: step 6, image 1 of 2 Sony Alpha NEX-C3 LCD Screen Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, remove the larger backplate from the LCD screen.
  7. Sony Alpha NEX-C3 LCD Screen Replacement: step 7, image 1 of 1
    • With your hands, gently remove the black plastic piece on the backside of the LCD screen.
  8. Sony Alpha NEX-C3 LCD Screen Replacement: step 8, image 1 of 2 Sony Alpha NEX-C3 LCD Screen Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, gently pull up and away on the ribbon cable connected to the motherboard, after which, the LCD screen should come off.
    • The motherboard ribbon cable has a specific connector.
To reassemble your device, follow these instructions in reverse order. However, when installing the ribbon cable, the connector has a specific step. The connector has a tiny flap that clamps down onto the ribbon cable in order to make it secure.
Jonathan Chen
690 Reputation
6 Guides authored
One Comment
Sir, my unit has many lines that appear on the screen. However, the lcd glass is pristine & has no cracks. Which part is defective? Is the lcd mother board the culprit? Thank you.
Stevie B - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 2,536
