Sony Alpha NEX-C3 Top Panel Replacement
  1. Sony Alpha NEX-C3 Top Panel Replacement, Top Panel: step 1, image 1 of 1
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Top Panel Replacement: step 2, image 1 of 1
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
  3. Sony Alpha NEX-C3 Top Panel Replacement: step 3, image 1 of 1
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
  4. Sony Alpha NEX-C3 Top Panel Replacement: step 4, image 1 of 2 Sony Alpha NEX-C3 Top Panel Replacement: step 4, image 2 of 2
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
  5. Sony Alpha NEX-C3 Top Panel Replacement: step 5, image 1 of 1
    • Gently lift off the top panel with your hands.
Jonathan Chen
690 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 801
