Sony BDP BX350 Motherboard Replacement
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: step 1, image 1 of 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: step 2, image 1 of 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: step 3, image 1 of 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: step 4, image 1 of 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: step 5, image 1 of 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: step 6, image 1 of 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: step 7, image 1 of 1
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: step 8, image 1 of 2 Sony BDP BX350 Motherboard Replacement, Motherboard: step 8, image 2 of 2
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: step 9, image 1 of 1
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: step 10, image 1 of 1
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
Kristen Vezina
413 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 649
