Sony BDP BX350 Wifi Card Replacement
  1. Sony BDP BX350 Wifi Card Replacement, Control Board: step 1, image 1 of 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Wifi Card Replacement: step 2, image 1 of 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Wifi Card Replacement: step 3, image 1 of 1
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350 Wifi Card Replacement: step 4, image 1 of 1
    • Remove both covers.
  5. Sony BDP BX350 Wifi Card Replacement: step 5, image 1 of 2 Sony BDP BX350 Wifi Card Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350 Wifi Card Replacement: step 6, image 1 of 1
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350 Wifi Card Replacement: step 7, image 1 of 2 Sony BDP BX350 Wifi Card Replacement: step 7, image 2 of 2
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
  8. Sony BDP BX350 Wifi Card Replacement, Wifi Card: step 8, image 1 of 2 Sony BDP BX350 Wifi Card Replacement, Wifi Card: step 8, image 2 of 2
    • Remove 6mm Philips head screw from wifi board.
  9. Sony BDP BX350 Wifi Card Replacement: step 9, image 1 of 1
    Buy
    • Remove the ribbon cable from motherboard using a pair of tweezers.
  10. Sony BDP BX350 Wifi Card Replacement: step 10, image 1 of 3 Sony BDP BX350 Wifi Card Replacement: step 10, image 2 of 3 Sony BDP BX350 Wifi Card Replacement: step 10, image 3 of 3
    • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
Kristen Vezina
413 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 6
All Time: 297
