Sony BDP-BX520 Port Board Replacement
  1. Sony BDP-BX520 Port Board Replacement, Disc Tray Cover: step 1, image 1 of 1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Port Board Replacement: step 2, image 1 of 1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Port Board Replacement: step 3, image 1 of 1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Port Board Replacement, Front Panel: step 4, image 1 of 1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  5. Sony BDP-BX520 Port Board Replacement: step 5, image 1 of 1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  6. Sony BDP-BX520 Port Board Replacement: step 6, image 1 of 1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  7. Sony BDP-BX520 Port Board Replacement: step 7, image 1 of 2 Sony BDP-BX520 Port Board Replacement: step 7, image 2 of 2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  8. Sony BDP-BX520 Port Board Replacement, Port Board: step 8, image 1 of 2 Sony BDP-BX520 Port Board Replacement, Port Board: step 8, image 2 of 2
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
  9. Sony BDP-BX520 Port Board Replacement: step 9, image 1 of 1
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
  10. Sony BDP-BX520 Port Board Replacement: step 10, image 1 of 2 Sony BDP-BX520 Port Board Replacement: step 10, image 2 of 2
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
  11. Sony BDP-BX520 Port Board Replacement: step 11, image 1 of 1
    • Carefully pull the port board free from the Blu-Ray player.
Collier
352 Reputation
3 Guides authored
Cal Poly, Team 8-41, Amido Winter 2015 Member of Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 351
