Sony BDP-BX620 Disk Drive Replacement
  1. Sony BDP-BX620 Disk Drive Replacement, Outer Cover: step 1, image 1 of 2 Sony BDP-BX620 Disk Drive Replacement, Outer Cover: step 1, image 2 of 2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Disk Drive Replacement: step 2, image 1 of 2 Sony BDP-BX620 Disk Drive Replacement: step 2, image 2 of 2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Disk Drive Replacement: step 3, image 1 of 3 Sony BDP-BX620 Disk Drive Replacement: step 3, image 2 of 3 Sony BDP-BX620 Disk Drive Replacement: step 3, image 3 of 3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Sony BDP-BX620 Disk Drive Replacement, Disk Drive: step 4, image 1 of 1
    • Remove the no-fuss ribbon cable connectors by gently pulling on them.
    • Pulling harshly may break the flat cables.
  5. Sony BDP-BX620 Disk Drive Replacement: step 5, image 1 of 1
    • Using the Phillips screw driver, remove the three screws.
  6. Sony BDP-BX620 Disk Drive Replacement: step 6, image 1 of 2 Sony BDP-BX620 Disk Drive Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Turn the device over and use tweezers to push the metal clasp until it comes off.
    • Lift the metal brace located over the disk drive and remove the disk drive and the metal brace.
Axel Cruz Jimenez
207 Reputation
3 Guides authored
USF Tampa, Team 1-6, Lacy Fall 2016 Member of USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 355
