Introduction
If your buttons keep getting stuck on your Blu-Ray Player, you will see in this guide that there are only a few screws to remove to easily get to the front panel.
Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
Don't forget, there are two more 12mm screws on the other side as well.
Now, on the front panel, you will want to remove the two 10mm screws on top of the device.
