Sony BDP-S3200 Disk Drive Replacement
  1. Sony BDP-S3200 Disk Drive Replacement, Sony BDP-S3200 Disassembly: step 1, image 1 of 1
    • Remove all cables from the device.
  2. Sony BDP-S3200 Disk Drive Replacement: step 2, image 1 of 2 Sony BDP-S3200 Disk Drive Replacement: step 2, image 2 of 2
    • Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
  3. Sony BDP-S3200 Disk Drive Replacement: step 3, image 1 of 1
    • Pull the top cover off by sliding back from the device once the screws have been taken out.
  4. Sony BDP-S3200 Disk Drive Replacement, Disk Drive Replacement: step 4, image 1 of 1
    • Locate the disk drive
  5. Sony BDP-S3200 Disk Drive Replacement: step 5, image 1 of 3 Sony BDP-S3200 Disk Drive Replacement: step 5, image 2 of 3 Sony BDP-S3200 Disk Drive Replacement: step 5, image 3 of 3
    • Lightly lift off the hook on both front rear side and the bottom of the device to remove the front panel
  6. Sony BDP-S3200 Disk Drive Replacement: step 6, image 1 of 2 Sony BDP-S3200 Disk Drive Replacement: step 6, image 2 of 2
    • Remove the two screws that attach the disk drive to the frame using a #1 Phillips screwdriver.
  7. Sony BDP-S3200 Disk Drive Replacement: step 7, image 1 of 3 Sony BDP-S3200 Disk Drive Replacement: step 7, image 2 of 3 Sony BDP-S3200 Disk Drive Replacement: step 7, image 3 of 3
    • Carefully pull the (3) three bands off vertically.
    • NOTE: There is a latch that needs to be lifted off before pulling the band out for the middle band.
  8. Sony BDP-S3200 Disk Drive Replacement: step 8, image 1 of 2 Sony BDP-S3200 Disk Drive Replacement: step 8, image 2 of 2
    • Lift the disk drive off of the device
2 other people completed this guide.
Tan Nguyen
132 Reputation
1 Guide authored
USF Tampa, Team S5-G2, Walkup Fall 2017 Member of USF Tampa, Team S5-G2, Walkup Fall 2017
USFT-WALKUP-F17S5G2
5 Members
3 Guides authored
One Comment
Where can I buy a Sony BDP-S3200 Disc Drive Replacement?
Andrew Padilla - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 705
