Sony BDP-S3200 Motherboard Replacement
  1. Sony BDP-S3200 Motherboard Replacement, Sony BDP-S3200 Disassembly: step 1, image 1 of 1
    • Remove all cables from the device.
  2. Sony BDP-S3200 Motherboard Replacement: step 2, image 1 of 2 Sony BDP-S3200 Motherboard Replacement: step 2, image 2 of 2
    • Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
  3. Sony BDP-S3200 Motherboard Replacement: step 3, image 1 of 1
    • Pull the top cover off by sliding back from the device once the screws have been taken out.
  4. Sony BDP-S3200 Motherboard Replacement, Motherboard: step 4, image 1 of 2 Sony BDP-S3200 Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Carefully detach the white strips from the motherboard.
    • Be sure to lift the black latch for the largest strip next to the disc drive before removing it.
  5. Sony BDP-S3200 Motherboard Replacement: step 5, image 1 of 3 Sony BDP-S3200 Motherboard Replacement: step 5, image 2 of 3 Sony BDP-S3200 Motherboard Replacement: step 5, image 3 of 3
    • Remove screw above HDMI OUT port.
    • Remove screw above DIGITAL OUT port.
    • Remove the three screws on the motherboard.
    • Use a #1 Phillips screwdriver to remove all screws.
  6. Sony BDP-S3200 Motherboard Replacement: step 6, image 1 of 2 Sony BDP-S3200 Motherboard Replacement: step 6, image 2 of 2
    • Remove motherboard from the device.
    • Be careful not to damage any components of the motherboard when removing it from the device.
3 other people completed this guide.
Brandon Correa
158 Reputation
1 Guide authored
USF Tampa, Team S5-G2, Walkup Fall 2017 Member of USF Tampa, Team S5-G2, Walkup Fall 2017
USFT-WALKUP-F17S5G2
5 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 424
