Sony BDP-S3500 Disk Drive Replacement
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3500 Disk Drive Replacement, Front Panel: step 1, image 2 of 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Disk Drive Replacement: step 2, image 1 of 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Disk Drive Replacement: step 3, image 1 of 2 Sony BDP-S3500 Disk Drive Replacement: step 3, image 2 of 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: step 4, image 1 of 2 Sony BDP-S3500 Disk Drive Replacement, Disk Drive: step 4, image 2 of 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Disk Drive Replacement: step 5, image 1 of 2 Sony BDP-S3500 Disk Drive Replacement: step 5, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Disk Drive Replacement: step 6, image 1 of 2 Sony BDP-S3500 Disk Drive Replacement: step 6, image 2 of 2
    • Carefully lift and slide the disk drive out of the casing.
V W
197 Reputation
1 Guide authored
One Comment
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 14
All Time: 450
