Sony BDP-S3500 Front Panel Replacement
Michael Meissner
Michael Meissner and 3 other contributors
Last updated on June 23, 2020
2 - 3 minutes
Easy
Introduction
Go to step 1
This is a guide to remove the front panel assembly of the Sony BDP S3500.
Be sure to review the troubleshooting guide, as most of the time the problems are due malfunctioning software rather than it being a hardware issue.
This guide will show you how to safely remove the front panel assembly without damaging the other components.
iFixit earns commission when you buy through these links.
  1. Sony BDP-S3500 Front Panel Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3500 Front Panel Replacement, Front Panel: step 1, image 2 of 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Front Panel Replacement: step 2, image 1 of 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Front Panel Replacement: step 3, image 1 of 2 Sony BDP-S3500 Front Panel Replacement: step 3, image 2 of 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
2 other people completed this guide.
Michael Meissner
220 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 158
