Sony BDP-S3700 Port Board Replacement
Luiz Barreto
Luiz Barreto and 3 other contributors
Last updated on March 4, 2020
6 minutes
Easy
Missing Steps
Introduction
Go to step 1
The port board is where the power and eject buttons, the IR sensor and the USB port are located. This guide shows how to replace it.
Tools
  1. Sony BDP-S3700 Port Board Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3700 Port Board Replacement, Front Panel: step 1, image 2 of 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Port Board Replacement: step 2, image 1 of 2 Sony BDP-S3700 Port Board Replacement: step 2, image 2 of 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Port Board Replacement: step 3, image 1 of 2 Sony BDP-S3700 Port Board Replacement: step 3, image 2 of 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Port Board Replacement: step 4, image 1 of 1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Port Board Replacement, Port Board: step 5, image 1 of 1
    • Flip the Blu-ray back up
    • Remove the ribbon connecting the port board to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Port Board Replacement: step 6, image 1 of 1
    • Use the PH1 to remove the 7mm screw on the port board.
  7. Sony BDP-S3700 Port Board Replacement: step 7, image 1 of 1
    • Remove the port board.
Luiz Barreto
627 Reputation
5 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2017 Member of USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,114
