Sony BDP-s7200 Front Panel Cover Replacement
  1. Sony BDP-s7200 Front Panel Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200 Front Panel Cover Replacement: step 2, image 1 of 2 Sony BDP-s7200 Front Panel Cover Replacement: step 2, image 2 of 2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200 Front Panel Cover Replacement: step 3, image 1 of 2 Sony BDP-s7200 Front Panel Cover Replacement: step 3, image 2 of 2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200 Front Panel Cover Replacement: step 4, image 1 of 1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: step 5, image 1 of 3 Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: step 5, image 2 of 3 Sony BDP-s7200 Front Panel Cover Replacement, Front Panel Cover: step 5, image 3 of 3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200 Front Panel Cover Replacement: step 6, image 1 of 2 Sony BDP-s7200 Front Panel Cover Replacement: step 6, image 2 of 2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200 Front Panel Cover Replacement: step 7, image 1 of 3 Sony BDP-s7200 Front Panel Cover Replacement: step 7, image 2 of 3 Sony BDP-s7200 Front Panel Cover Replacement: step 7, image 3 of 3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200 Front Panel Cover Replacement: step 8, image 1 of 2 Sony BDP-s7200 Front Panel Cover Replacement: step 8, image 2 of 2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 214
