Sony Bloggie 3D Player Back Cover Replacement
  1. Sony Bloggie 3D Player Back Cover Replacement, Front Cover: step 1, image 1 of 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Back Cover Replacement: step 2, image 1 of 2 Sony Bloggie 3D Player Back Cover Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Back Cover Replacement, Back Cover: step 3, image 1 of 2 Sony Bloggie 3D Player Back Cover Replacement, Back Cover: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player Back Cover Replacement: step 4, image 1 of 2 Sony Bloggie 3D Player Back Cover Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
Timothy Tran
1 Reputation
2 Guides authored
Cal Poly, Team 7-12, Maness Winter 2013 Member of Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 401
