Sony CDX-GT540UI Back Panel Replacement
  1. Sony CDX-GT540UI Back Panel Replacement, Wiring Harness: step 1, image 1 of 1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Back Panel Replacement: step 2, image 1 of 2 Sony CDX-GT540UI Back Panel Replacement: step 2, image 2 of 2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Back Panel Replacement, Back Panel: step 3, image 1 of 1
    • Locate back panel.
  4. Sony CDX-GT540UI Back Panel Replacement: step 4, image 1 of 3 Sony CDX-GT540UI Back Panel Replacement: step 4, image 2 of 3 Sony CDX-GT540UI Back Panel Replacement: step 4, image 3 of 3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  5. Sony CDX-GT540UI Back Panel Replacement: step 5, image 1 of 1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  6. Sony CDX-GT540UI Back Panel Replacement: step 6, image 1 of 1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
3 other people completed this guide.
Odelkys Marquez
1,139 Reputation
7 Guides authored
USF Tampa, Team 10-2, Brown Fall 2014 Member of USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,180
