Sony CDX-GT540UI CD Drive Replacement
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: step 1, image 1 of 1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI CD Drive Replacement: step 2, image 1 of 2 Sony CDX-GT540UI CD Drive Replacement: step 2, image 2 of 2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI CD Drive Replacement: step 3, image 1 of 3 Sony CDX-GT540UI CD Drive Replacement: step 3, image 2 of 3 Sony CDX-GT540UI CD Drive Replacement: step 3, image 3 of 3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  4. Sony CDX-GT540UI CD Drive Replacement: step 4, image 1 of 2 Sony CDX-GT540UI CD Drive Replacement: step 4, image 2 of 2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI CD Drive Replacement: step 5, image 1 of 1
    • Remove front panel.
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: step 6, image 1 of 1
    • Locate back panel.
  7. Sony CDX-GT540UI CD Drive Replacement: step 7, image 1 of 3 Sony CDX-GT540UI CD Drive Replacement: step 7, image 2 of 3 Sony CDX-GT540UI CD Drive Replacement: step 7, image 3 of 3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  8. Sony CDX-GT540UI CD Drive Replacement: step 8, image 1 of 1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  9. Sony CDX-GT540UI CD Drive Replacement: step 9, image 1 of 1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: step 10, image 1 of 1
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  11. Sony CDX-GT540UI CD Drive Replacement: step 11, image 1 of 2 Sony CDX-GT540UI CD Drive Replacement: step 11, image 2 of 2
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  12. Sony CDX-GT540UI CD Drive Replacement: step 12, image 1 of 2 Sony CDX-GT540UI CD Drive Replacement: step 12, image 2 of 2
    • Remove top panel.
  13. Sony CDX-GT540UI CD Drive Replacement: step 13, image 1 of 1
    • Pull up CD drive slightly.
  14. Sony CDX-GT540UI CD Drive Replacement: step 14, image 1 of 1
    • Disconnect motherboard connection.
  15. Sony CDX-GT540UI CD Drive Replacement: step 15, image 1 of 1
    • Remove CD drive.
2 other people completed this guide.
Odelkys Marquez
1,115 Reputation
7 Guides authored
USF Tampa, Team 10-2, Brown Fall 2014 Member of USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Members
7 Guides authored
One Comment
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 745
