Sony CDX-GT540UI Front Panel Replacement
  1. Sony CDX-GT540UI Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI Front Panel Replacement: step 2, image 1 of 2 Sony CDX-GT540UI Front Panel Replacement: step 2, image 2 of 2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI Front Panel Replacement: step 3, image 1 of 3 Sony CDX-GT540UI Front Panel Replacement: step 3, image 2 of 3 Sony CDX-GT540UI Front Panel Replacement: step 3, image 3 of 3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  4. Sony CDX-GT540UI Front Panel Replacement: step 4, image 1 of 2 Sony CDX-GT540UI Front Panel Replacement: step 4, image 2 of 2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI Front Panel Replacement: step 5, image 1 of 1
    • Remove front panel.
2 other people completed this guide.
Odelkys Marquez
1,139 Reputation
7 Guides authored
USF Tampa, Team 10-2, Brown Fall 2014 Member of USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 3,015
