Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: step 1, image 1 of 1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Fuse Replacement: step 2, image 1 of 2 Sony CDX-GT540UI Fuse Replacement: step 2, image 2 of 2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: step 3, image 1 of 1
    • Once you have removed the wiring harness.
    • Locate the fuse.
  4. Sony CDX-GT540UI Fuse Replacement: step 4, image 1 of 1
    • Using your index finger and thumb on either side of the fuse.
  5. Sony CDX-GT540UI Fuse Replacement: step 5, image 1 of 1
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
Odelkys Marquez
1,139 Reputation
7 Guides authored
USF Tampa, Team 10-2, Brown Fall 2014 Member of USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Members
7 Guides authored
1 Guide Comment
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 63
All Time: 10,336
